Shrill dialogue on most voices on Sony Bravia tv
Megan4
New
Does any Sony Bravia owners have a problem with the sound of dialogue on their sets.I find that many voices sound shrill and high pitched and very annoying to listen to.It’s not that I can’t hear it,just too high pitched for comfort.I have had my tv for quite a long time,but only recently find this problem.Hope it’s not my hearing,but don’t think it is.Have no trouble with ordinary conversation.Megan4
11 REPLIES 11
Pascale_F
Hi Megan,
Which model TV is this regarding?
Thanks,
Pascale
Megan4
New
Thanks for your reply.Sony Bravia,not sure if there is a number too.I’ve had it for a good number of years and don’t have the instruction booklet now.is there a model number on the actual tv?
Pascale_F
Hi Megan,
Please see this page regarding finding your model number.
Thanks,
Pascale
Megan4
New
Thanks for the info.Model no is:KDL32S2000/10/20/30.Is this how I reply to posts?
Sent from my iPad
Megan4
New
Bravia model no is:KDL32S2000/10/20/30. Thanks,found the number in settings info.
Pascale_F
Thanks, Megan.
I’m in the process of checking this with the relevant team now and this thread will be updated as soon as I have a response.
Thanks,
Pascale
Win_88
Specialist
Hi Megan4,
Have you tried to reset sound settings? Maybe something was changed by accident? You can do that by going to Settings - Sound - Reset.
Win_88
Megan4
New
I have tried every combination of the audio settings over time and it makes no difference at all.As far as I can tell the settings are as the should be.Thanks
Sent from my iPad
Win_88
Specialist
Hi again Megan4
If the TV always sounded like that, I don't think it can be considered to be faulty. But if it only started to happen after a certain point, then it can be useful to think back about things that may have changed, for example, if you are playing content through an external device and you change it, the newer one may sound different, or changing where the TV is by moving it from one room to another or changing the space around it as this affects the ambient sound of the whole room.
If none of the above is applicable, and the TV doesn't sound the same out of the blue, I think this can be a fault.
Win_88
