RX10 M4
G.Tazzyman
New
RX10 M4
I have recently bought an RX10M4. There is no sticker on the inside of the instruction manual giving my password. The info file PMHOME is empty so no password there either. I need the password to set up the WiFi etc - so what am I supposed to do now?
3 REPLIES 3
Pascale_F
Hi G.Tazzyman,
Welcome to the community.
It might be best to contact Support about this issue. Have you tried looking at the back of the instruction manual or inside the box, just in case?
Thanks,
Pascale_F
IamNic
Hi @G.Tazzyman,
go to the menu, then to "Application List" and then to "Smart Remote Embedded".
If you click it, it will show your cameras password.
- nic
dfm1951
Explorer
Sorry, but there is no 'application list' in my menu settings- where is this specifically, please?
