Made in Japan - radiation?
SOLVED
profile.country.sv_SE.title
perrand
Visitor
Hi,
I bought a  CyberShot DSC-HX5V and noticed that it was made in Japan. Is it possible to get information about where in Japan it was made and is there any danger that the camera or some of the parts have been exposed to radioactive dust or other radiation sources (I'm thinking of Fukushima).
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
StartTheCar
Contributor
Thanks for your post about your new Sony camera – we hope you enjoy your new HX5.
To your specific question, since the incident at Fukushima all Sony products on sale in the UK have been imported through a port or airport where the authorities have instigated screening for products from Japan.
As you would expect, these tests are being conducted in accordance with the appropriate European regulations and safety levels and there have been no instances to date of contamination of Sony products.
Hope this helps put your mind at rest.
Best regards
Lee
1 REPLY 1
StartTheCar
Contributor
Best regards
Lee
