Yet more Sony Bravia issues!
John00001
Explorer
Hi everyone. My KDL43W809C Often comes up with an on-screen message 'your television is no longer  connected to the internet'. A few seconds later it will say 'your television is now connected to the internet'. I don't seem to lose any signal, but it's an annoying error message that sometimes comes and goes all night. Any ideas? Many thanks.
3 REPLIES 3
Anonymous
Not applicable
Hi there
Is your tv connected via Wifi?  If so, try changing the wireless channel on your router.
Can i also assume that you have the latest firmware installed?
Cheers
John00001
Explorer
Thanks mate. How do I do that on my router? Yes, I have the latest UK updates so far... Thanks again
Anonymous
Not applicable
Hi there
To change wifi channels on your router, you will need to look at the instructions for your router.
Most of the time, you log into your isps router via a web browser using 192.168.0.1, find the wireless section and then select a different channel.
Cheers
