XG95: Wired connection and CAM-module?
profile.country.SE.title
Isak80
Member
If i use a wired internet connection with my XG95 am i still able to use the Airplay 2 and the built in Chromecast? Also, at the moment i'm only using a Tivo-box cause i can watch one program and record two others. If i use a CAM-module and smart-card instead, will i still be able to record two separate tv-channels at the same time?
2 REPLIES 2
Hi Isak,
Unfortunately this won't work. The TV needs to be connected to the WiFi network to use Chromecast etc..
You can record one channel and watch another unencrypted SD channel. Other combinations are not possible.
Cheers
Peter
Sonyvores
Contributor
If your Tv is wired to the router you use for wifi at home, it will work.
