Can the wall bracket for the Frame 55" QLED model fit a Sony KD-55AG9 tv ?
Which model will fit closer to the wall ?
Distance for the Frame 55" TV set is 45.8mm from the wall so I would like to know if I can get the same depth with the 55" AG9.
Hi THEPINKHOUSE-007,
That depends on the bracket - if it is VESA conform and has a hole pinch of 30x30 cm you might be able to use it with the AG9.
Cheers
Peter
