A Sony Sound bar for my XG9005
SOLVED
DavidLB
Explorer
Hi All,
I'd like to buy a Sony Sound bar to go with my TV. The TV (49 inch) doesn't have Dolby Atmos, so I was wondering what sound bar would be really good with it...
1 ACCEPTED SOLUTION
Accepted Solutions
Joe_Dohn
Specialist
I believe so yeah, even if the TV doesn't have native support for Atmos (except for Netflix, since that implementation is not Dolby TrueHD but still Atmos) you can still "pass through" Atmos content to a support audio system, like for example the sound bar mentioned by Peter.
3 REPLIES 3
Hi DavidLB,
What about the HT-XF9000?
https://www.sony.co.uk/electronics/sound-bars/ht-xf9000
Cheers
Peter
DavidLB
Explorer
Hi Peter,
Would I be able to experience the dolby atmos feature with the TV I have?
Joe_Dohn
Specialist
