Abbrechen
Stattdessen suchen nach
Meintest du:
KD-49XF7096
GELÖST
profile.country.BE.title
Claude7220
Entdecker
KD-49XF7096
My Tv: KD-49XF70
Can it hurt to completely switch off my TV every day?
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Hi Claude,
No, that won't hurt your TV. I'm practicing this as well for some years.
Cheers
Peter
Lösung in ursprünglichem Beitrag anzeigen
5 ANTWORTEN 5
Hi Claude,
Cheers
Peter
Claude7220
Entdecker
Thanks Peter
I have dirty spots on my TV on the left and right side. On the right (see photo) it's worse than on the left, it seems to be dust but this is not it. Every two days I have to clean it with a slightly damp cloth. This TV is an Led-EdgeKD-49XF7096-2.jpg
Claude7220
Entdecker
Thanks Peter!
The_Black_Rose
Spezialist
Hi Claude7220,
This seems a bit unusual to be honest. Can you provide a clearer picture showing the whole screen?
Cheers,
The_Black_Rose
Claude7220
Entdecker
@The_Black_Rose  schreef:
Hi Claude7220,
Cheers,
The_Black_Rose
I tried to take a picture as clear as possible, it's very difficult te get a better picture TV Sony a.jpgTV Sony b.jpg
