I own a KD-43XE8077 has instability with itvplayer, all4 regarding subtitles and you view?
Fred70
Explorer
These issues have been reported by many consumers. Have sorted thanks to a reported fix. Yet not a very responsive control of the Android state the TVs gets into. Better instruction set needed from either Youview, Android, I players or Sony. Maybe it should involve all to ensure the tv can run in a more seamless manor. All4 started doing subtitles without any instruction from me as a further example. Also the fix does not last after switch off to next time switch on.
1 REPLY 1
Anonymous
Not applicable
Hi there,
Welcome to the community. :slight_smile:
Thank you for the feedback. I will pass this on, and somebody should get back to you.
Best wishes,
M
