Deel jouw ervaring!
I recently bought a Sony Bravia kd43xe8004 for my Xbox one X because it is supposedly HDR, however when setting up my Xbox it says my TV doesn’t support HDR 10, can someone explain why this is?
Hi there,
Welcome to the community.
Have you updated to the latest firmware?
Best wishes,
M
Hi @Destroy_unit_20,
Try using only HDMI 2 or 3 on the TV. Then also make sure that Enhanced Mode is set to Enabled for the HDMI inputs under HOME > SETTINGS > EXTERNAL INPUTS
Cheers,
Dutchice
