My KD-49X8309C tv has stopped working. It froze in the middle of operation and is now stuck in an endless reboot regime and I cannot restart it. I have tried updating the firmware by USB 3 times per Sony's procedure which has not worked: I have tried to do a factory reset according to Sony's instructions: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-49x8309c/artic... This has not worked either. Any other advice please? |
Hi aileenomahony,
If all the above steps did not work you should get in touch with a repair centre.
Cheers
Peter
Thanks. I have got in touch with them.
