Sony A57
profile.country.en_GB.title
cooke69
Explorer
Sony A57
Hi all
I received my Sony A57 at the weekend have have only been able to use it a small while but has been great and the photos on the LCD have come out brillient to.
I need to get a cheap LED light for my movies any suggestions?
Also the LCD/view finder on the A57 screen seems a little grainy at times, just to clear my mind would this be due to low light conditions due to the mirrorless system?
Thanks
2 REPLIES 2
blaireau_photo
Visitor
Hello cooke69 :slight_smile:
First of all, it is perfectly normal for the viewfinder screen to appear 'grainy' in low light conditions.
As far as I am aware, the only option for an LED light would be the Sony HVL-LE1 product which is described here:
http://www.sony.co.uk/product/dsa-flashes---lights/hvl-le1
Looking around some online stores, prices range between £150 and £200 for this LED light which is fully compatible with the A57.
Thanks,
Simon
cooke69
Explorer
Cheers Simon
Looks like i'll be saving up for the LED light
