Hi, i just wanted to adress issue i have with wildlife my combo. I just cannot get sharp images out of it. I tried everything, but i guess i have to get another copy of the lens as mine is probably not good.
Hey zakravak, which camera model are you currently using?
Yeah sorry! I'd recommend adjusting the peaking focus function: https://helpguide.sony.net/ilc/2040/v1/en/contents/TP1000422735.html?search. You can also try initializing the camera settings by following this. Hope this helps!
My 200-600 was brilliant when I first started using it on my A1 .... I think the Firmware was 1.2x or something. As soon as I updated to 1.3x (I don't recall the exact version) and the 1.32, it was very, very unreliable! In fact I have not even used it in anger for a couple of years or so, as I know it was so bad.
FF to today. I took the plunge this week to go through the a1 firmware upgrade process from 1.32 > 2.01 > 3.00 ..... and I just tested it against my Sigma 500mm/f5.6, and the Sigma absolutely blows it away. The Sony is still really bad, and now I am thinking of getting rid.
