New Alpha 7ii not working with new SEL24240: no focussing
SOLVED
Photo7iiFun
New
I have a new Alpha 7ii with a SEL24240 Sony lens (bought new in October last year).
Worked until Christmas.
Now, picked it up to use tomorrow, and find
1)  I cannot focus the lens at all -> pictures (even on Auto) all out of focus
2) No F number relayed to camera display (shows as "F--")
3) Pressing on the C3 button, error msg stats lens not attached.
4) The half-depression auto-focus (on the shutter button) is no longer available:  camera just takes picture (or tries to) on just lightly pushing on the shutter button
Anybody else had this problem ?
As a fairly new user of this camera/lens, I just wondered if this really is a hardware fault or I may have accidentally pressed a button somewhere which could have caused this.
1 ACCEPTED SOLUTION
Accepted Solutions
Photo7iiFun
New
Hi,
Found the problem with assistance from Sony customer support.
It was the memory card.
Removing and re-inserting did the trick:  afterwards everything worked perfectly again.
Amazing how a poor/missing connection with the memory card can cause so many apparently unrelated problems.
3 REPLIES 3
profile.country.NL.title
Strampke
Try this:
- take the battery out for a minute and place it back
- do a camera factory reset.
Be aware that the battery is charged.
Griffin_door
Specialist
I agree with Strampke, as well try to unmount the lens and re-mount it again.
Also i think that the lens isn't fully compatible with the A7M2, you might wanna check this:
https://support.d-imaging.sony.co.jp/www/cscs/lens_body/?mdl=ILCE-7M2&area=gwt&lang=en_G
Photo7iiFun
New
Hi,
