Imaging Edge Desktop - Viewer and tethering
Hi,
I would like to use my MacBook Air with a 13" screen for tethering in the studio.
The view application and tethering works very well with my A7RiV camera, but the picture on the 13" screen is very small. A lot of space is used for the preview icons at the bottom and volumes to the left. I would prefer just a full screen image of the last picture taken. Is there any options/settings to accomplish this ? Anyone else that have a different solution is welcome too. I considering buying an extra screen to solve the problem but would like to check for an cheaper solution first 🙂
1 REPLY 1
HannahEd01
Hey recessphoto, the software is supposed to be used with a computer, if you're using an extension screen, that's not up to the software to change what's on it I guess.
