a35
profile.country.en_GB.title
ktm250f207
Visitor
a35
please help camera did connect to laptop but know when i plug it in usb it say check connection thanks ian
1 REPLY 1
Mick2011
New
Hi Ian, welcome to the Sony Forums :slight_smile:
You don't mention which OS you're using, but it may be that updating your PC has change the way it behaves with your USB connection :thinking:
Often a quick solution to this kind of problem is to remove the memory card form the camera and use an accessory card reader instead.
Cheers
Mick
