Hi I was waiting a long time since the Z5 for a new one and then i heard there is no Z6 comming.. sad..
anyway i got myself Sony Xperia XZ and I have a Sony SWR12 Smart Band
but they dont like each other so I opened a Support case with Sony Support .. Response maybe one of your applications block the Low engergy bluetooth aka Bluetooth® Low Energy (BLE)... and I must uninstall .. but not what i shal uninstall...
I googled this one and found nothing on this and with my phones before i had more than one Bluetooth device and never a Issue...
also the XZ Pairs fine with by Sony Speakers SRS-BTV5 ....
so I asked which application could it be .. no answer on this...
so I put my Phone back to Factory settings... and see NO still not working
NFC is recocnices .. it points me to the App for the SWR12 installing it end then again .. NFC reconiced but never connects via bluetooh ... also told the support but no answer on this...
they seem to be very bussy at the moment..
So lets try here
guys any Any Idears ?
Solved! Go to Solution.
@Andreas1983 You need to reset SWR12 to factory settings by shutting down the band, then take the finger off the button and press it again for about 10 seconds. It should vibrate and a blue light should blink.
wow
working like a charm
Thanks
Great!
