- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Bug with DATA connection notification not fixed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @victor91r,
Have I understood you correctly in that this notification keeps reappearing after you dismiss it, even if you haven't changed any setting?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Would it be possible for you to take a bug report of this the next time it happens? If so I can forward this internally.
To do this:
- Go to Settings > About phone > Build number, tap 7 times on the build number.
- Go back and select Developer options then turn on "USB debugging".
- Select Logger buffer size and change it to "4 M"
- Restart your phone, then with for this to happen
- Go back to Settings > Developer options, select "Take bug report".
When the report is ready you will receive a notification. Tap the notification to share it. I suggest you upload it to Google Drive and then choose to share a public link to the upload and include the link in the PM.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks! I have forwarded this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello,
I have the phone for a week and I is very annoying that every time I turn on my mobile notification appers.
My phone is free and bought in Spain.
Is there any solution for this?
Sony has thought to remove it in an upcoming update?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @julianmb76,
Do you mean the popup saying "Allow mobile data?"? At the bottom of that message there should be a checkbox saying "Don't show this again", press the checkbox to mark it and then press OK. After that this message should no longer appear.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No, is this notification:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm also getting this message from time to time, it says mobile data is disabled, when i clear the notification, it will come back to the screen from time to time, even when the mobile data is turn off on my XA Ultra, and also even when i'm connected to wifi network, it says that i've been using my mobile data and i'm being charge for mobile data usage even i'm using my wifi connection, Please Help
Thanks!
