Deel jouw ervaring!
Opgelost! Ga naar oplossing.
Try to restart your device.
Have you inserted it correctly? Did you check the card in a PC?
Keep us updated.
The device is relatively new, so I think up to 200GB should be just fine. If it's a Sony/Samsung/Sandisk, that should be ok.
