I lost my charger. Can anyone suggest me what charger should i use by specification?
you can buy one of the most recent Xperia/Sony chargers and it will work just fine
Hi @Tryyf, sorry to hear about what has happened.
As @uliwooly wrote, you can use any charger that is included with an Xperia product, either a phone or a tablet.
The charger that is included together with your device can vary between both markets and retailers, but the most common one is the EP880.
Note! VDC=Volts Direct Current, mA=milliamps
In later products, the charger that is included with the device, at least in the Nordic market where I'm situated is the UCH20, however that one has the same output as the EP880!
I hope that helps in your hunt for a new charger!
