WH-1000X M3 on and charging?
Hello
It might be a strange request. But is it possible to add to the firmware to be able to have the headset being ON while charging?
Story/Reasoning, dont have to read:
My headset I use on my computer is getting old and was thinking using the WH-1000X M3(WH) here aswell, but do not know when I will have time to charge (or remember to charge).
I am used to having a wire from my old headset so having a charging cable for WH wouldn't bother me. But having an unusable downtime due to charging would bother me.
1 REPLY 1
IamNic
Hello @FriisTeching,
while they are not intended to be used while charging, you can use them with the supplied 3.5mm audio cable while they are charging via USB-C - then of course without NC and any other of the features usually available when the headphones are switched on.
- Nic
