NW-A35 Bluetooth headphones compatible
Dncbkk
New
Are any Sony Bluetooth  headphones fully compatible with the Nw-a35 player? By fully compatible I mean sound settings can be adjusted such as the equaliser.
3 REPLIES 3
Sonyvores
Contributor
That doesn't depends of the headphone but of the players :wink:
According to the manual
  • "When there is an active Bluetooth connection, the sound quality settings are invalid."
so I guess it's a no =(
profile.country.SK.title
rplonka
Explorer
What does than LDAC stand for? I was assuming to reach high quality audio using bluetooth (LDAC) Sony compatible headphones as for example MDR-EX750BT. Anyone please?
Sonyvores
Contributor
LDAC is Sony proprietary codec for bluetooth high audio quality sound. You have bit perfect CD quality through LDAC 😃
