MEX-N6001BD - Bluetooth/App Remote
SOLVED
jamigue69
New
When the unit is paired to my phone, it appears that you have the option to connect to the phone device or the phone audio and documentation indicates that it should automaticallly reconnect as last connected. Well this just does not happen. Whenever I turn the unit on it fires up App Remote on my phone and this takes the connection. The only way to get audio is to quit the App Remote app on my phone and reselect source.
This is utterly ridiculous - has anybody else experienced this? Am I doing something wrong? Sony documentation is useless. What do I have to do for the unit to automatically connect to my phone audio? Delete App Remote? It looks as if it may be useful but it's going off my phone very soon.
1 ACCEPTED SOLUTION
Accepted Solutions
jamigue69
New
I'll answer it myself, just uninstall that useless hunk of crap App Remote from your phone.
1 REPLY 1
jamigue69
New
