MDR-DS6500 - Multiple headsets
mav2k16
New
Hi, can anyone advise if I am able to use 2 sets of these headphones with one transmitter so 2 people can listen to the same movie at the same time for example?
Many thanks for your help,
Wayne.
1 REPLY 1
Anonymous
Not applicable
Hi there
Unfortunately you can only have one set of headphones attached to the base-station with this model - additional headphones are not supported.
If you have a Sony Bravia TV, you can set the TV to output audio via headphones as well as the TVs internal speakers by enabling Headphone/Speaker link - but you would need to connect the headphones to the headphone socket on the TV and not via optical.
Cheers
