i-tunes 10 support for A845
profile.country.en_GB.title
vankeays
Visitor
am i missing something? just got the walkman, but i cant drag and drop from i tunes, i'm assuming it's because it don't support i tunes 10, which i updated the day b4 i got the walkman ..... D'oh !!!!!!!
Message was edited by: vankeays
Tags (1)
2 REPLIES 2
Drumzman
New
Hi vankeays,
Have you installed the Content Transfer software?
The latest version (1.3) is available from Sony's support website if not - link is below.
http://support.sony-europe.com/dna/wm/nwvp/nwvp.aspx?site=odw_en_GB&m=NWZ-A845
If you install this, then each time you connect your Walkman to your PC a small Content Transfer window opens up, and if you drag and drop music from your iTunes library to this you should be fine.
I recently updated to iTunes 10 and I can still transfer to my Walkman no problem! :slight_smile:
Hope this works for you!
vankeays
Visitor
thought i already had v1.3, but downloaded anyway, still had the same 'problem', ie i select a track/file from i-tunes, and the content transfer box disappeared! then!..... i tried dragging to the minimised cont/trans box, which made my main box reappear and,   hey presto!!!  music on the move is back!    d'oh!!!
so in a round about way,  result!!
cheers for the quick reply and prompt to try again !! lol
