Headphones - constant popping sound - MDR-NC500D
profile.country.en_GB.title
tribalhunter
Visitor
Hi,
Has anyone had a constant 'popping' sound while using the Sony noise cancelling headphones - MDR NC500D.
It can be really annoying. It doesn't stop when you turn the music off, or pull the jack from the iPod/iPad/PC Laptop.
It regularly occurs when sitting in the window seat of an aeroplane or train, which is the whole purpose of these headphones.
thanks
Ben
Tags (3)
2 REPLIES 2
mithcd
Visitor
Looks like a hardware isse to me. When did this start happening? You might want to check the warranty here too. Call support, I would suggest. https://imagicon.info/cat/12-13/vmware_happy.gif
Mine do this, too! To me it sounds like they are adjusting for air pressure.   Very annoying.
