- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello - I recently got the XM3s. I had a pair before but there was a fault in them.
i note in the new pair the adaptive sound control does not work. The wheel just keeps moving but the noise cancelling does not change.
I’m on 2.0.0 (should I upgrade? I hear so many negative things!). I have iOS 12.2 on an iPhone X.
i tried resetting and restoring to factory settings as well.
anyone else have this issue?
thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@IamNic wrote:Hello @LondonSound,
have you tried to reset the headphones or reinstall the Headphones Connect app?
- Nic
Thanks for your message. Before I read this I decided to change the location settings. It was previously at Always On, I changed it to When using app. I noted when this happened location settings actually got used. I then deleted the app and reinstalled.
It worked!
thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello @LondonSound,
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Nic
It worked!
thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
