XP Drivers for VGN-N11H
Teamdanger
Visitor
Had a problem with my Vaio and had to wipe my HDD so have re-installed XP and am starting from scratch again but i'm having trouble locating drivers for audio/video/wi-fi/etc
Can anyone help my problem? Thanks in advance.
Mark
3 REPLIES 3
Blencogo
Hi Mark and welcome.
Go to the download page for your Vaio here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-N11H_W
You will find all the Original Drivers and Utilities under the ORIGINALLY INSTALLED Tab and any subsequent updates will appear under the UPDATES Tab.
:wink:
Teamdanger
Visitor
I have just done this, this morning but i'm having quite a bit of trouble working out what to do, i'm not the most computer aware person so i apologise if i appear to be a bit dumb. how do you install all the drivers into the laptop?? :thinking:
Blencogo
Hi Mark,
Download the .zip files of the Original Drivers and Original Utilities to a location where you can find them.
In Windows Explorer, right-click on the .zip file and choose 'Extract All'
Extract to C:\
The Drivers (and Utilities) will be listed in C:\Drivers (C:\Utilities)
Most drivers and all utilities will contain a "SETUP.EXE" file - just double-click on the setup file to install.
Some drivers will not contain a SETUP file but will contain a .INF file - to install these you must go to Device Manager.
In Device Manager, find the uninstalled device (with a yellow !), double-click on it and choose 'Update Driver'. Choose 'No, not this time' -> 'Install from List or Specific Location' -> 'Don't Search, I will choose a driver to install' -> 'Have Disc' and browse to the location of the .INF file.
I think all the updates run and install automatically as long as the original is installed.
Good Luck.
:wink:
