The wireless connection is ON when I boot up but is turned OFF a few seconds later as the boot progresses. I know that I can disable the connection, restart then enable the connection but it is tedious. Some software interferes with the connection.
I believe the same software changes the functions of my S1,S2 and S3 buttons; when I press S3 I get the calculator instead of the CD ejector.
It is possible that these problems occurred since I changed internet providers from SFR to Orange.
worjackie
