Hi
I have just bought 512MB ram for my FS215B from Crucial and they say that it is OK to mix my new RAM with the old ie 512 and 256. What I need to know is which slot is number 1 as this should hold the 512MB stick and the 256 goes into the second slot.
Thank You
That doesn't really matter anymore these days.
You have to make sure thoug that they both are from the same type (not referring to the size) and speed
Please see other double post..
atticmaster, please try not to double post as this wastes peoples time & causes confusion.
Sorry
It's ok
