VPCL21M1E touch screen drivers doesn't work
profile.country.el_GR.title
apateonas83
Visitor
I reinstall winodws ultimate on my PC and now cannot recognise the touchscreen...any idea what can i do? I also made the mistake to not do do recovery discs!!!
3 REPLIES 3
rich912
Contributor
Hi apateonas83,
Have you installed the original touch screen utility? It can be downloaded from Support.
http://www.sony.co.uk/support/en/product/VPCL21M1E_B/updates
If you wish to return to the original OS then as long as you have not removed the hidden recovery partition you can start the recovery utility by tapping F10 at boot (before you see the Vaio logo).
Rich
Go n-éirí an bóthar leat
apateonas83
Visitor
I have completely remove all the partitions on my PC. I had a problem with the last BIOS update and then i thought that it was from windows. I couldn't make recovery disks, so i installed an other original copy of windows 7. After that i couldn't use touch screen again...:smileysad:
rich912
Contributor
You haven't said whether you tried installing the touch screen utility from the link I provided...
Rich
