vpcee2s1e ram upgrade problem
profile.country.en_GB.title
delta1153
Visitor
hi iv had my laptop for over a year and decieded to upgarde the ram i used mrmemmory and the compatibility softwear and found the maxium supported ram was 8gb when i got the ram and installed it the laptop would get to the windows log in screen and i would get the blue screen i thought one of the modules must have a fult so i tryed one at a time but after 5-10 min by its self it would blue screen but the orginal ram worked fine i emailed them to find out what the problem was but the engineer isnt sure of the issue so there sending me a new set out but he doesnt think this will solve the issue so does anyone have any ideas whats going ?
callum
0 REPLIES 0
