Vista Home Basic
profile.country.en_GB.title
CarlMichaelJwtt
Visitor
Vista Home Basic
I know this is not Vaio issue but I am a Vaio VGNN21M owner. I have another tower computer I am running on Windows XP and I am trying to update to Vista Home Basic but th CD fails to load.
I have tried to change BIOS settings to read CD as first choice but this does not work, can any of our exports help me out wioth a solution,gratefull for any help. Carl
4 REPLIES 4
Blencogo
Hi Carl,
Does the desktop computer have a SATA hard drive?
:thinking:
CarlMichaelJwtt
Visitor
Thank for your reply sorry I do not know what hard drive ??
Thalamus.
Champion
Hi Carl,
to check if your desktop can run Vista try using the Windows Vista Upgrade Advisor, use the following link: Windows Vista Upgrade Advisor
CarlMichaelJwtt
Visitor
Hi Thalamus nice to hear from you, I run the Vista prog you suggested it says not enough memory. I do not understand this memory available 66.36 GB Free Out of 74.52GB Capacity available. CPU Intel r Celeron r CPU 2.66 GHZ if this inf helps?? Car:l
