Video Resolution changes after standby mode on XL-202
darkmeridian75
Visitor
Hi Guys,
Again me having some important issues to share with you.
I don't know why, but since few days after standby mode, Windows changes the resolution from 1440 x900 to 1080x1024. I tried to reinstall video driver, but nothing. I have also installed the new driver for nvidia video card but again nothing!
Could you help me?
PS
I have always trouble with audio settings under MediaCenter. i am unable to increase or decrease volume using remote control. The only way to do that is to use WAVE volume control. Any suggestion?
TNX
Cheers
3 REPLIES 3
profile.country.de_DE.title
itbroker
Visitor
Darkmeridian75,
Question Nr. 01
Solution:
To resolve this issue, disable the 3D Maze screen saver in Full Screen mode:
1. Right-click an empty space on the desktop and click Properties.
2. Select the Screen Saver tab.
3. If 3D Maze screen saver is the one selected, click Settings.
4. Clear the check box in front of Full Screen in the Maze Setup window.
5. Click OK, Apply and OK again.
Question Nr. 02
I did not found an answer yet... I keep trying...
darkmeridian75
Visitor
Darkmeridian75,
Question Nr. 01
Solution:
Question Nr. 02
HI there and thank you for your reply
unfortunately I do not have 3D maze.
The screen saver is Vaio Information Flow.
any further suggestion?
cheers
darkmeridian75
Visitor
Hi Guys,
Could you help me?
PS
TNX
Cheers
Again me.....
someone can help me about my troubles with XL-202?
Further
I want connect my XBOX 360 via XL-202, now I am using D-sclaer to view Xbox signal on my screen, anyone could suggest some other software?
TNX
