VGN-BX197XP harddisks
ewinau
Visitor
I bought a VGN-BX197XP, which has two 80 GB harddisks,both active according to the device manager. However, I see a drive C with with a capacity of 32.6 GB and a drive D with a capacity of 34.9 GB. I think these are parts of the first drive, but where is the second? How can I activate and use the second drive?
Thanks for your help.
Ewald Naumann
12 REPLIES 12
Blencogo
Hi Ewald and welcome to the Club.
Your Vaio has a multi-function bay which can hold a number of extras, including a second 80GB hard drive.
Have a look in your USER MANUAL on Page 39 to see how to access it.
Do you actually have the second drive installed or do you have a DVD-RW drive in the bay?
In Explorer, what drive letters do you have visible?
:slight_smile:
ewinau
Visitor
Thanks for your answer.
There is actually a second hard drive installed, it is visible in the divice manager.
The multio function bay contains a DVD-RW drive
In ExplorerI see a drive C (32.6 GB) and a drive D (32.6 GB), quite likely a haad drive divided into two partions.
It might be that the system uses the second 80GB drive as a mirror for data security. Is this possible? If so, how can I change it?
Ewald
rich912
Contributor
It may possibly be that the disk has not yet been initialized. To check this open Control Panel > Administrative Tools > Computer Management > Storage > Disk Management. You should find Disk 0 which will contain C and D together with the recovery partition (no drive letter allocated) and also a second disk with no drive letter allocated and possibly marked as not initialized.
The help section will guide you through the process but whatever you do don’t make any changes to the recovery partition (approx 7.5 Gig).
Go n-éirí an bóthar leat
ewinau
Visitor
Thank you very much Rich, this was the problem. Thre disk was not activated and not formatted. After sctivating and formatting it everything is fine. Now there is a new dribe E with a capacity of 74.5 GB.
Thanks agian for the very helpful support in this forum.
Ewald Naumann
rich912
Contributor
You're very welcome Ewald. I am pleased to hear that you now have your full hard disk capacity:smileyhappy:
profile.country.en_GB.title
kee-lo_
Member
How cool is that, having 160GB in a laptop? :cool:
Thalamus.
Champion
:cool: Very cool indeed :smileygrin:
profile.country.de_BE.title
stephanius
Visitor
Slightly jealous with my mere 100GB. :smileygrin:
kee-lo_
Member
I only have 30GB
