I have recently loaded a new version of XP on my laptop and i am trying to load the original drivers.
I am just having a bit of trouble installing some of them most of them are simple setup.exe
But my problems are with installing:
Network 1 and 2
Video
How do install these on my system?
Hi andrewisback,
for the video drivers..
Go to Start > Run type devmgmt.msc and press OK, Device Manager window should open, double click Display adaptors.
Right click once on the default graphics and select properties.
Select the 'Driver' tab and click on Update driver.
A new Hardware Update Window will appear, Select Don't search I will choose the driver to install and click Next,
Select Display adapters and click Next,
click Have Disk and browse to the folder that contains your downloaded driver,
select NVSZ.INF and click Open, Click OK
then click Next to install NVIDIA GeForce Go
Wait while the Wizard installs the new software
Click Finish when the installation complete screen appears
Restart the computer to finish
