Vaio VGN -AR71S - Removing the battery
SOLVED
profile.country.en_GB.title
miranda.bend
Explorer
If I remove the above computers battery, will i still be able to use the laptop with just the mains adapter plugged in and  switched on ????
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi Miranda.bend,
Yes, the AR71S should run perfectly well on the power adaptor
with the battery removed.
Rich
Go n-éirí an bóthar leat
3 REPLIES 3
rich912
Contributor
Hi Miranda.bend,
Rich
miranda.bend
Explorer
Thanks very much for your reply, i searched everywhere for the answer to this question and didnt find one straight forward answer lol much apreciated!!!
rich912
Contributor
You’re welcome Miranda:slight_smile:
