does any1 know how to stop updates from restarting ur vaio
Hi snackiest,
welcome to Club VAIO..
What operating system are you using.?
thanks for the nice welcome :smileyblush:
i just installed window 7 32 bit, i have a vaio sr 39
Hi snackiest,
this should work as a temporary solution (I would still recommend that you restart your vaio asap to manually complete the update process)..
Click Start, then click All programs followed by Accessories.
In Accessories Right Click on Command Prompt and select Run as administrator.
In the Command Prompt window (next to C:\windows\system32>) type: net stop “windows update” and then click Enter
Hopefully you should see something similar to the image below appear..
Then close the CMD window.
When you restart your Vaio the windows update service will be restarted and when you next download an update that requires a restart you'll receive the prompt again..
