I bought the Sony Vaio VPCCA1S1E.
I need to have a notebook with two video outputs for use with two monitors and external keyboard and
mouse.
By connecting two monitors (VGA + HDMI), the VAIO software forces me to use up to two monitors at a time
but never able to disable the laptop screen.
Is there a way to use two external monitors on this notebook?
Thanks,
MArco
I bought this laptop for the same reason, but how did you manage to plug in both a vga cable and a hdmi cable at the same time? the ports are so close together that the vga cable covers part of the hdmi port when plugged in. so how did you manage this feat?
Thanks
I must cut the plastic of vga cable and polish the right side of metal.
The problem of the dual screens I solved simply by closing the lid of the laptop 🙂
Bye Marco
