screen help
profile.country.en_GB.title
mickyw
Visitor
screen help
tried to calibrate monitor with hex2bit now my colours are washed out how can i get back to default settings
  hope someone can help thanks micky
2 REPLIES 2
Blencogo
What model Vaio are you talking about and which Graphics provider does it use?
In general terms, you need to right-click on a blank area of the desktop -> Properties -> Settings -> Advanced
and look for the Colour Management Tab under your Graphics Adapter.  You will see a list of Colour Profiles associated with your display and you will need to remove the new profile or reset the profile to factory basics.
:thinking:
mickyw
Visitor
thanks went into ati and reset to factory settings
