I want to change graphic card on my VAIO Laptop NR 38s any suggestion where i would get and is it easy to change. OR advice graphic card model NO
Solved! Go to Solution.
Hi nadaman,
The graphs chip is soldered to the motherboard and is not economically replaceable. For a notebook of this age it would be cheaper to buy a new machine.
Rich
