reinstalling SonicStage Mastering Studio
profile.country.en_GB.title
davidbridgeman
Visitor
Hi Guys
Can anybody help me with reinstalling SonicStage Mastering Studio. I get an error message just as it starts the reinstall (***IS_STRING_NOT_DEFINED*** FILE:C:\Documents and Settings\All Users\ error: the system cannot find the path specified) the path it is looking for is an windows XP path c:\documents and settings\all users, problem is, I am on Vista. This path does not exis.
HELP
Regards Atticmaster
2 REPLIES 2
Blencogo
Which version of SSMS are you trying to install?
Are you sure it is a Vista Compatible version?
:thinking:
davidbridgeman
Visitor
I am using the version that is on my recovery partition. It has worked in the past with no problems don’t know the version at this point but is vista compatible
Thanks Atticmaster
