Recovery of VGC-RA 304
SOLVED
tabaheights
Explorer
I had to do a reinstall on my VGC-RA 304 due to a surprise crash, so armed with my recovery discs I set about the task, after some time my computer was up and running, but I have been left with a problem that I cannot get automatic updates to work I have service pack 2 loaded but cannot get service pack 3 downloaded. Can anyone help
1 ACCEPTED SOLUTION
Accepted Solutions
tabaheights
Explorer
Sorry to mess you about I have that working now, thanks again for your valuable help.
3 REPLIES 3
Blencogo
Hi tabaheights.
Did you reinstall the Sony original operating system or did you use a commercial version of XP?
What error message do you get when you try to download XP SP3?  Have you tried disabling any third party Firewall or Anti-Virus?
Check through the pre-requisites for SP3 installation and troubleshooting suggestions on Microsoft's website here: -
http://support.microsoft.com/kb/950717
Try the suggestions there (if you haven't already) and come back if you continue to have a problem.
:thinking:
tabaheights
Explorer
Hello Blencogo, thanks for the advice I have now SP3 loaded and running, but it's not all good news Vaio update is not working, the recovery discs I used were the original ones I created when I purchased the computer many years ago.
tabaheights
Explorer
