Problems with power supply input on aw11s
rich71281
Visitor
Came to use my laptop this morning and noticed the power supply input plug was excessively loose in the socket. Is it a possibility that something has snapped inside the socket as i'm not familiar with the inner workings of the laptop or is the socket soldiered directly onto the board which could have somehow come loose because the laptop seems to have been overheating recently? Was wondering if the fault would be covered under warranty but i doubt it. Thanks
1 REPLY 1
Thalamus.
Champion
Hi rich71281,
you will need to discuss this with Vaio support, to find contact details for Sony Vaio support..
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 2: Select your VAIO model, next to Select Model Category - Select your model from the drop down list, in your case VGN AW.
Then next to Select Model - select AW11S
Then click Log-In
Once logged select Get In Touch
