Over the past two days I am facing a problem in switching on my laptop. When I press the power button, the power light and the two battery lights glow and then cut off immediately. the other three lights flicker for a second as the first three go off.
It appears as thought there is a short. I took out the battery, but that didn't seem to help.
Now, the funny thing is that this happens only at times, and if I leave the laptop and come back to it after a while and try again it works.
Does anybody have any ideas?
Have you tried it on just batteries?
yes, I have... the battery is almost dead. A full battery only lasts until the laptop starts up. So far it hasn't worked with battery only.
Thanks, Arunjay
Hi ,
my Problem is the same...
Sony Vaio Fx-605...
