mike_coreit
Member
PCV-W1/G Power Supply
Hi does anyone know where I can get a replacement power supply for a PCV-W1/G ?
The current one is a Delta Electronics model. DPS-190BB-1 A
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Hi Mike,
First place to try should be Vaio Support to see if they will sell you one.  You will need to use the out of warranty premium phoneline 0905 0310006.
If that is not possible, I think you will need to import one from the US.  Several places seem to have stock but this one advertises international orders: -
http://www.sparepartswarehouse.com/Sony,Computer,Part,146877213.aspx
:wink:
4 REPLIES 4
Blencogo
Hi Mike,
:wink:
rich912
Contributor
Yes, I know where to get one but it is probably ‘a bit late now’...
Rich
Go n-éirí an bóthar leat
profile.country.en_GB.title
celavey
Visitor
Go to any stores near you that sells PC parts. You will surely get a power supply from them and in a cheap price.
mike_coreit
Member
Thanks for the tips. I ended up finding a refurbished one on eBay.
