PCG-K195BP CD-RW
sam_son83
Visitor
PCG-K195BP CD-RW
Hi again, sorry to hasstle you all again, its just im trying to sort out my new laptop,
the only prob im having now is the cd-rw. i mean does the model even have one???? its a PCG-K195BP and i was under the impression it had one, ive installed NERO EXPRESS but its only seeing sone "Image Recorder" and not the cd-rw.
Can sumone please help me out.
Thanks for all ya help
Sam
3 REPLIES 3
JoeB.
Visitor
hi,
yes the model has a DVD/CD-RW combo drive...
i have posted some pre-checks in your other thread...
Joe
sam_son83
Visitor
Im just going through the points that you listed for me now but they all seem ok, the drive f:// says its dvd/cd.rw but im trying a different version of Nero to see if it works, if not can you reccomend any other burning software ?
thanks again for your help
Sam
sam_son83
Visitor
Just to let you know ive sorted this prob out now, it ended up being an old version of Nero which didnt work with WinXP so i got the new version, thanks again for your help
