PCG-FX705 Problem:
mward
Visitor
PCG-FX705 Problem:
A few weeks ago the sony vaio mentioned above started freezing. I guessed it maybe overheating and so sent it away to a vaio repair center. They had a look and said it was down to the Hard Disk, so they have replaced it and sent it back. Already it has started freezing. So i decided to update the BIOS to Version R0121K5 from the VAIO-Link site. It applied ok, it turned itself off, i then turned it on and restored default settings and saved changes. The only problem is that now it will do its post and i can access the bios but as soon as it gets to the stage of booting it does nothing. So i cant boot from HDD, FDD, or CD i have changed boot orders and even tried a network boot. Any idea's. I cant flash it again as i cannot get to boot from anything. Any ideas? Could really do with some urgent help.
Thanks....
2 REPLIES 2
clubuser
Visitor
hmmm, this sounds like a propoer support case - i'd say that your initial problem was not fixed by VAIO Link this is what I would tell them. Honestly i would leave my fingers off fixing bios etc.
I am not sure if this forum is the right place to get help for this kind of problems.
Good luck with it :four_leaf_clover:
profile.country.en_GB.title
kee-lo_
Member
Have to agree with CU, it's a case of calling VAIO-Link.
