No Sounds on Bluray Movies !!! HELP ! please !!!!!
steveinwigan
Visitor
Hey,
I have recently upgraded to Vista Ultimate.
Everything seemed to have gone smoothly, UNTIL !!!
For some reason I have no sound when playing Bluray movies back ( or normal DVD through the Blu ray drive).
I have checked the device manager and it says everthing is fine.
I have checked the sites and cannot find anything to help.
Does anyone know how I can fix this problem?.
Thanks in advance !
I have a Sony Vaio XL202 !!
2 REPLIES 2
profile.country.en_GB.title
kee-lo_
Member
The best thing to do is reinstall WinDVD, and get all the updates, or even just use PowerDVD, as it's better at handling more complex sound compression such as TruHD and AAC.
steveinwigan
Visitor
Thanks Mate.
Will give it a go tonight !.
PowerDVD ??. Is this another program to play the movies, via?
I thought I could only use the Windvd BD programme..
IS it a free download or would I have to pay?, and where would I find a download ?
Thanks again for your help.
