My Hard drive is knackered
profile.country.en_GB.title
nashrj
Visitor
It seems like my Hard drive is knackered and I didnt back up anything on my laptop :slight_frown:
I need to re-instal Windows 7  but I never got a CD when I bought it as it was already installed.
Does anyone now what I need to do?
1 REPLY 1
Blencogo
You should have been reminded to make your own System Recovery discs when you first bought the Vaio.
Unfortunately if you did not make recovery discs and your hard drive has failed, you need to contact Vaio Support and ask them to sell you a replacement set of Recovery Discs.
:thinking:
